Merging analog DMX EN12
Hey there,
How many analog DMX Inputs are possible to merge? Is it possible to merge 4 analog Inputs with backup mode? For example it uses port 1 and if there is non valid data port 2 and so on!
If not is it possible to merge 4 inputs per htp? I would like to merge 4x DMX 1 into one single out and DMX 2 same.
Hi @mikeemike
To do this, you could configure ports 1 thru 4 as inputs. These inputs could then all be set to send sACN universe 1, but at different priorities.
You could then configure another port on the EN12 to listen to sACN universe 1. This port will then listen to the active port with the highest priority.
Make sure the Signal Loss option for each Input Port is set to Stop Sending.
Would it be possible to merge these 3 inputs with a 4. input ? How many Inputs are possible to merge by HTP “analog” same as the sACN number of 2 Inputs ?
If you are using the dedicated “Merge” option for each port, the port can be configured to listen to a maximum of two sACN/Art-Net streams.
