So after successfully importing a model and saving it to the library.
Attempts to add said model to object list fails.
Screenshots below.
Any assistance is much appreciated.
Screenshots below.
The first thought is that you stil have the modeler open with the library. A MSD file can only be open in 1 module at a time. If this is not the problem, then would it be possible to send us (support@lighthouse.nl) the files ?
Both the modellibrary with the imported object and the file which you imported.
That way we can investigate why the file won’t open.
Problem solved.
I had the modeler open.
Thank you.
