The CLU tool is designed to discover and configure NETRON nodes.
It finds nodes across all network ports, and can find them independent of IP Address ranges. E.g. a node with 2.x can be discovered from a 192 .x network port.
IP addresses and name can be set from the menu, once the IP range matches, the nodes are accessible and will open the correct web page. Future versions will add firmware updates directly from the tool and all settings will be directly adjustable without the need for a web browser.
There are some limitations until the full release is done as it requires some updates to the Netron firmware. The changes will be part of Netron V3.0
- Device renaming does not work from the tool
- IP Address change reboots the node
For now please report back if the tool discovers your nodes, especially larger systems.
