NETRON EN12 RDM
Hi.
I’m trying to discover/list my RDM devices (artnet) for each port of my multiple EN12s but i can’t.
Version is 2.9.4
RDM is activated on all ports (artnet output)
RDM processing is ON
It seems that the EN12 is not forwarding RDM infos.
Or maybe there is an API endpoint to list the RDM devices directly ?
Any tips would help.
Thanks.
Hi @artcontr
Welcome to the forum.
Thank you for the information. What console are you using to perform Art-RDM discovery? If you are using an MA console, we are aware of a compatibility issue between MA and the EN12, which prevents MAs from obtaining a list of RDM devices from the EN12.
Netron firmware 3.0.0 is available for EN12, to resolve this issue. If you would like to update your EN12, please first save a backup file, by navigating to System > Maintenance > Save Current Settings using a browser.
To install this firmware update, please click the link below on a Windows PC, to download Netron Central Utility 1.1.1…
Obsidian Control Systems
Once downloaded, install the software, and then launch it with your EN12 connected. Make sure your PC and EN12 are on the same IP scheme. Then navigate to the Firmware Update tab, and click the upload arrow below Update Firmware for the EN12. The installation will begin, with the progress shown on the EN12’s OLED display.
Once the firmware update is complete, please then attempt to discover connected RDM devices using your MA. Please let us know how you get on.
Hi. Thanks a lot for the information.
No i’m not using GMA, i want to use OLA framework or directly your API for our inhouse-built control center.
I’ve just upgraded to v3 and do more tests.
But if you have a documentation i’d love that.
Thanks a lot again.
The Netron EN12 supports the REST API, however this does not report information about connected RDM devices.
For this, you are best to use the Art-RDM protocol to obtain a list of RDM devices from the EN12.
