NETRON EN4 DMX output
Dear all
I recently purchased a Netron EN4. When setting it up, I set the IP address on the device and configured the ports to output dmx via ArtNet. The device was directly connected to a MacBook in the same subnet (10.0.0.0/24). When trying to output ArtNet via Qlab and via MagicQ, the unit did not function properly (flashing blue leds on the DMX ports). I changed to a preset (ArtNet 10.x) to make sure I did not make a configuration error. This did not work. After rebooting the unit, it briefly seemed to function (the leds stopped blinking - solid blue). On the next reboot, the unit did not function anymore.
I can reach the unit via the web-interface on the configured ip.
I did a test with another device (ELC DMXLan Buddy) and the same MacBook configuration, and this worked immediately. Can you help me?
Thanks in advance!
Mike Neyens
Hi @Techniek
Welcome to the forum.
Great to hear you have a Netron EN4. Thank you for confirming that this is set to a random 10.x.y.z IP address using the Art-Net preset. By default, the 10.x.y.z Art-Net preset will use a /8 subnet (255.0.0.0). Therefore, I would recommend setting your Mac to an IP of 10.0.0.1, with a subnet of 255.0.0.0. QLab and MagicQ on your Macbook, should then be able to detect your EN4, and will then be able to send Art-Net to it.
Hi @Edward
Thanks for your reply. It seems I did not make myself completely clear. When changing to the preset, I changed the IP configuration of the Macbook to be within the same subnet as the EN4.
I was also able to reach the web-interface in both configurations (manual and preset), so maybe this means it is not necessarily a network issue?
All the best,
Mike
Hi Mike,
Thank you for the information.
Please could you confirm the IP address and subnet configured on your Mac?
Please then connect to your EN4’s webpage using a browser, and take a screenshot of the home screen and the System > Status screen. Please then post these screenshots on the forum, and I will take a look.
What’s the firmware of the EN4?
Blinking blue LED indicates that it’s not receiving DMX packets.
Keep in mind that EN4 may look at the Art-Net packages shifted by one Universe (both 0 and 1 based are allowed)
There is a setting to change this in the menu and web interface.
