how to update the firmware of an EP4. I lost the ip of the EP4.
Thanks
Thanks
I’d recommend downloading the CLU utility to a PC and put the PC and EP4 on the same network (provided both have DHCP). Let the CLU discover the node and then push the firmware update from there. It will most likely reset the node, so check you setting (or save them to a file), that way you can set it back up.
Where can I find the CLU utility?
Thank you very much for your help
Great it works. Thanks a lot. Good job
