We have finished Netron Version 3 for all EN and EP products as well as BS10 and DA2410V. RDM10 will follow, at which point we will fully publish the version.
The V3 files are included in the newest CLU installer, all updates are easy to push to multiple nodes at once from the UI.
Please note that to update BS10 you have to use an EN12i and access the web interface. BS10 can be updated when connected with a simple button click.
V3 is a pretty massive feature update and enhances network protocols and RDM communication across the Netron line.
Download and run the latest CLU installer:
Release 1.1.1 (07/09/2025)
Includes
Node Firmware 3.0.0 (EN12, EN12i, EN12-45, EN6 IP, EN6D, EN4, EP4, EP2, EP1, EP1D, DA2410V, BS10)
Node Firmware 2.9.5 (RDM10)
Switch Firmware 1.0.0 (NS8, NS8 IP)
Note: NETRON devices are not compatible with Internet Explorer or Firefox.
It is recommended to use the NETRON Central Utility to discover, configure and update NETRON devices.
BS10 firmware is included with EN12i and must be updated manually. Use the BS10 Firmware Upgrade button from the System/Maintenance web menu.
Improvements
Added support for EP1D
Enhanced support for NS8 / NS8IP
Added support for EN6D Emergency Cues
Fixed Cue Options - Link Cue not working
Fixed Freeze during Save Cue
NETRON Node Firmware V3.0.0 (07/09/2025)
New features
NETRON-15 sACN Sync support
NETRON-18 Art-Net Sync support
NETRON-20 DMX Port Labels
NETRON-22 Added Signal Loss Option to DMX Input Ports (Hold DMX, DMX 0)
NETRON-24 “Cue Off” Fade Time
NETRON-26 Signal Loss and Recovery now allow Fade Time
NETRON-29 Added DMX Port Live Status Feedback on Web Interface
NETRON-31 Gateway IP Address field added to IP Settings
NETRON-34 New Identify Status from Device Display is shown on Web Interface
NETRON-36 Web Interface Security option with username/password, new Security Sub Menu
NETRON-38 RDM Device Count Indication per port
NETRON-41 sACN per channel priority now supported on EN12, EN12i, EN6D, EN6IP, DA2410V
NETRON-64 sACN Output Priority Number to DMX Input, Cue and Merge resend Ethernet
NETRON-76 Added Contact Closure / BS10 Priority Setting (DMX Source or Cue)
NETRON-78 Reboot Option added to Display Menu
NETRON-115 New “Cue Grid” remote web page (IP Address/Cues.html)
NETRON-129 “Disable Cue” option added to Cue Link list
Trigger Off Function for BS10, hold button for 5s to “untrigger” the input
Improvements
NETRON-4 Changing Network Protocols no longer shifts the Universe Number
NETRON-11 Improved RDM / DMX data packets interleaving so connected devices do not assume a loss of DMX traffic
NETRON-21 Revised Clone Port Menu
NETRON-28 Improved Web UI table rendering
NETRON-33 User Presets can be loaded with or without IP address
NETRON-45 Identical Art-Net or sACN Universes from two sources are automatically merged HTP
NETRON-80 Improved RDM over Art-Net communication that prevented some consoles (like MA2) and RDM monitoring software seeing the discovered devices
NETRON-109 Block IP address of 0.0.0.0
NETRON-112 Clone Port settings are shown in web status page
Cue Playback is indicated with yellow status on port LEDs and Display
Bug Fixes
NETRON-6 RDM-10 sometimes unstable output during Art-NET to DMX handover (RDM10 2.9.5)
NETRON-7 Resolved node lockups with certain ARP packages
NETRON-10 Corrected sACN keep alive refresh rate created by DMX Input ports
NETRON-16 Art-Net trigger was only working with Universe 1
NETRON-70 Fixed DMX output issues during LLRP or other multicast discovery commands (EN6IP, EN6D, EP1, EP1D, EP2)
NETRON-77 Enabling Universe Monitor Interrupts Port 1 Output
NETRON-79 BS10 LED feedback inconsistencies
NETRON-93 Cue Fade & Hold Time Last x1.5 Longer Than Defined
NETRON-98 Device Name cannot include some special characters
NETRON-101 DMX Workshop port configuration mistakenly affected NETRON specific DMX Merge settings
NETRON-110 User Preset corruption when the label had 12 characters
NETRON-114 sACN Output generated by the node included Sync packets
Improved DHCP subscriptions and timeouts
Corrected EP1 disconnections from some sACN sources
