Please update your NETRON nodes to Version 2.2
https://obsidiancontrol.com/netron/etherdmx-nodes
Release Notes for NETRON EP4 - EN4 - EN12 - RDM10
(C) 2020 - Obsidian Control Systems
V2.2 (11/06/2020)
Requires V2.2 .nfw and .img
Web .img file is now unified for all devices
Web interface is NOT compatible with Internet Explorer.
Improvements
- added new IP presets for 192.x and 172.x automatic address
- added new NETRON presets for Artnet and sACN 192 and 172 automatic address plus others
- added signal loss indication to display (red outline)
- revised state engine of cue toggles so “signal loss” option is used when cue is turned off. this allows to toggle between two cues with a single remote switch
- added IP, Type and Identify switch to sidebar. Identify sends devices into red/white blink mode.
- added “hidden” owner preset page. Use /Preset_Owner.html to lock existing user presets from overwriting.
- added User Factory Reset. Use PIN 007 to reset to user preset #1
- changed Preset web page layout and command order to avoid accidental overrides
- changed System Menu arrangement for clarity
- irrelevant options are hidden when possible
- added more details to DMX port feedback on web interface
- increased cue fade/hold time to 99 minutes
Bugfixes
- enabled RDM by default on RDM10
- improved some unwanted device reboots on browser refresh of RDM10
- Cues crossfade correctly from current state to stored value (instead from 0)
- improved signal lock after changes
- improved some bootup states that sometimes waited for value changes
- devices no longer send DMX 0 after bootup if “wait for data” option is set
- improved sACN priorities to ignore source IP and simply lock to the highest priority stream
- fixed some web interface styles and labels for consistency
- Display DMX Test colors were inverted, now corrected to Red=Increase, Green=Decrease
