A new NETRON Version 2.6 is available.
It resolves a bug when recalling EN12 and RDM10 presets from the web ui, and improves support for sACN merge on ports.
It is availabe to download on the product pages:
https://obsidiancontrol.com/netron/etherdmx-nodes
Release Notes for NETRON EP4 - EN4 - EN12 - RDM10
(C) 2020 - Obsidian Control System
Note: Updates require two files, .nfw per device and .img web package
NETRON devices are not compatible with Internet Explorer.
V2.6 (01/07/2021)
Requires V2.6 .nfw and V2.4.img
Improvements
added support for automatic HTP merging of two sACN streams from different IP sources with identical priority
Bugfixes
Resolved a bug where recalling some presets in the web interface can cause a lockup
V2.4 (12/08/2020)
Requires V2.4 .nfw and .img
Bugfixes
Display Timeout was set to disabled, now is set to 5min
Display Timeout “disabled” kept the OLED at full brightness, now added a dim down of display after 5 min
RDM10 could not boot unless connected to PC
EN12 showed hiccups in the DMX test screens when the web interface was refreshed
Improved some RDM detection issues
V2.2 (11/06/2020)
Requires V2.2 .nfw and .img
Improvements
- added new IP presets for 192.x and 172.x automatic address
- added new NETRON presets for Artnet and sACN 192 and 172 automatic address plus others
- added signal loss indication to display (red outline)
- revised state engine of cue toggles so “signal loss” option is used when cue is turned off. this allows to toggle between two cues with a single remote switch
- added IP, Type and Identify switch to sidebar. Identify sends devices into red/white blink mode.
- added “hidden” owner preset page. Use /Preset_Owner.html to lock existing user presets from overwriting.
- added User Factory Reset. Use PIN 007 to reset to user preset #1
- changed Preset web page layout and command order to avoid accidental overrides
- changed System Menu arrangement for clarity
- irrelevant options are hidden when possible
- added more details to DMX port feedback on web interface
- increased cue fade/hold time to 99 minutes
Bugfixes
- enabled RDM by default on RDM10
- improved some unwanted device reboots on browser refresh of RDM10
- Cues crossfade correctly from current state to stored value (instead from 0)
- improved signal lock after changes
- improved some bootup states that sometimes waited for value changes
- devices no longer send DMX 0 after bootup if “wait for data” option is set
- improved sACN priorities to ignore source IP and simply lock to the highest priority stream
- fixed some web interface styles and labels for consistency
- Display DMX Test colors were inverted, now corrected to Red=Increase, Green=Decrease
V2.1 (06/02/2020)
.nfw file
Improvements
- sACN alternate start codes are handled properly / ignored
Bugfixes
- Resolved DMX ports sometimes going to sleep after RDM communication
- Resolved sACN issues with ETC systems
V2.0 (06/01/2020)
This version requires two files, .NFW and .IMG
Improvements
Added better support for setting options from DMX Workshop
Device Name
Identify device with red/white blinking LEDs
Port Direction and Universe Settings
IP Address -
Added System option “Artnet Offset”
Universe 1 is mapped to Artnet 0-0 (compatible with ONYX/M-Series)
Universe 1 is mapped to Artnet 0-1 (compatible with newer Artnet 4 devices) -
Universe Range for Artnet and sACN is now 1-32767
Home screen shows device label is display for easer identification
Added Web Firmware version to Status Page
Added automatic forwarding when changing manual device IP address
Bug Fixes
- When the port set to input,playing CUE changed the ports of the direction
- Current cue was not updated in display
- Improved RDM discovery for Elation Fuze Range and others
- Fixed bug with 2.x.x.x automatic IP calculation
- Firmware Update is no longer case sensitive (both .dfw and .DFW will work)
- Artpoll packages identify port count correctly
