I’ve spent some hours learning a bit about Onyx. Currently using Onyx with the Enttec DMX Adapter.
Question 1: Why do I sometimes have to use Clear Clear to continue? For example, I’ll be using presets and all of a sudden nothing works. Clear, Clear and all is back to normal.
Question 2: Can I attach the Pan/Tilt POPUP to a function key?
Question 3: Can I reorder the Left Panel functions?
Thanks
Pat,
I’ll try to answer some of these questions to the best of my ability. On the Clear Clear, it is hard to say, it might depend on your programming flow? It is possible, that you have recorded a cue and the programmer is waiting for you to “re-select” lights. Also, be aware when using presets, that if the fixture is not “in the preset” then it won’t be affected by it. Just something to check maybe?
The Pan/Tilt Pop Up can be toggled from a function key. Just so you are aware, there is already a “toggle popups” at the top right of the screen views if enabled. But to assign a toggle to a function key…go to the menu and unlock the workspaces. The “Assignments” section are now enabled and you can select functions. Select the function location, select “Commands” / “Channel Visualization” / “Toggle”.
The “Sidebar” (Left Panel Functions) can be re-ordered, but not maybe as easy as you hope. You can’t “drag and drop” / “rearrange”, but you can re-assign a new view, window, command, fixture, etc. You might want to create a new workspace to mess around with and get use to.
Also you may have something in the command line window…delay, fade , edit, etc and clear clear removes it from focus
on the CLEAR CLEAR issue.
When you operate using presets, you are using the programmer on the selected/altered fixtures. If you are layering Programmer data, over Playbacks (cuelists. overides, etc). The programmer will be mixing and overriding your playbacks. Eventually the programmer will have to be fully cleared [CLEAR CLEAR] or select the individual lights directly (or through fixture groups), and clear just those lights ‘loaded parameters’. Working on the fly should be mostly playbacks and cues, and minor touches with the presets on the programmer, at least for me anyhow.
Otherwise if you mix your playbacks, and programmer data on the fly; use them to create looks…
-However-
…Just try this little extra step before you get to your data dead end.
- Select ALL fixtures, [LOAD LOAD] then [RECORD] to a playback
- Fade in the new playback, in the background; and then [CLEAR CLEAR]
Clear Clear empties the programmer, its not a cue Release.
In theory you shouldn’t see an interruption (maybe a flicker?)
If you try this, let us know how it worked out. Thanks!
Have Fun, Be Creative!
