Not sure if this were to fall under hardware or software but here we go. Updated my first gen M1 to Onxy about a few weeks ago. Seemed to install properly and what not. Ran a couple shows without major incidents. The new software was very laggy and the calibration just would not, well, calibrate. Annoying, but minor buggy things that can be worked around. As of 2 days ago, when I power on console, everything seems to run fine software-wise that i can see, however I have no control over anything.
When I pull the DMX line out of port, fixtures flash as they are not receiving signal as normal. When I plug the DMX line IN, all fixtures move to the home position as if i just powered them on (not my DMX home), the fixtures stop flashing as if they are receiving DMX, but i still have no control over anything, dimmers included.
Went through every setting on the console that Im aware of, opened up the console to check connections, seems fine. Didn’t know if there was a known bug, a corupt file transfer from the old OS ( I did try starting a brand new file as well) Any sort of help would be much appreciated.
Cheers!
Jason
St. Louis, MO
