Hey all, I’m having issues with SACN output on my elation enode 4. I’m on onyx version 4.8.1237.0 and I have the elite liscence, ip’s are 2.0.0.x subnet 255.0.0.0 all 4 ports of the node show up as etherdmx devices with the correct universes (5-8). The node displays check marks on all 4 of the universes, indicating its receiving data. But I don’t get any dmx data outputting from any of the ports on my node. If I send via artnet I do get output, but more and more often guest LD’s are pushing me to use SACN so I’d like to get this working.
A couple questions to help troubleshoot.
- Are you on a console or PC?
- What are the network settings for the NIC adapter? (Is other traffic on the network, ie CITP, NDI, XNet, Remote, etc?)
- Is sACN output enabled under EtherDMX settings and the range set?
- What firmware is the EN4 running? (2.9.4 is now out)
- Is sACN set as the Protocol on the EN4? (This would be a place to start)?
How this helps,
Oh got it, question 3, thank you.
I just needed to turn on SACN. Didn’t think you needed to turn it on under network settings AND etherDMX settings.
