Hi All I have got my ns8s and i have been very impressed. But … I havent been able to get them to work with thezactrack smart system. I am sure it is a setting that i may be missing. I have managed to get sacn, ndi across multiple nodes using multiple vlans and trunking. Just tried to make a Zactrack vlan and dindnt work. surly theybdont need to be in the same ip range to work would have thought the ip was just to configure the units. All m,y other bits were in the 192.168.x.x ranges and the zactrack plays in the 172.x.x.x range.
other thing i noticed there is nowhere to add a saftey chain the the unit unless you get a m12 or m10 o ring.
As far as I know about networking, they do have to be in the same ip range to communicate. I would change the ip on the zctrack or on the ns8 to see if it works.
Will do. Its back Sunday Night and I will try and find some time to have a look over next week. Zactrack ssaid to make it as dumb as possible and it should work. The Vlans wouldnt be an issue as long as there is enough bandwidth.
No it hasnt. But havnt had a chance to look at it. I am planning to try and have a look tomorrow. Would be good if we could export vlan settings. Make a custom vlan and import it. Also a ns8 with a screen or a bigger one.
Looking at using the neutron ns8 switches with zactrack smart. Looking at a switch on front truss. Rear truss and rack to assist with cabling on a touring show. Has anyone worked out the best setting for these switches. I am hoping to find some test times but… days getting longer and running out of time.
The Netron NS8s shouldn’t need any specific configuration to use Zactrack Smart.
If other devices are connected to the NS8 that do not need to communicate with the Zactrack system, you could configure the ports connected to the Zactracks devices to be on their own VLAN. The management IP address of the NS8, does need to use the same scheme as the Zactracks devices. If the devices on the Zactracks VLAN have static IP addresses, make sure that this VLAN on the NS8 has the DHCP server disabled.
