Hi everyone,
I am running an NX-Touch on onyx 4.6.1230 and I try to have odd even bumbs with fade on the side buttons playback but when I press them with the Timed feature they always have velocity active on them and if I remove the timed option they act like normal flash button
Is it a bug… missing feature… or problem with the hardware
Thanks
Overrides have no fade time. Use normal Cuelist Mode instead.
No the fade works perfectly when I execute it from the virtual board. Only the intensity doesnt start at 100% . And the behavior (when pressed from the nx-touch right extra button) matches the one of the velocity feature (the intensity is based on the pressure you aply on the button)
@Matthias, I’d like to bump this post. Still doesn’t appear to be fixed 2 years later.
I understand the ONYX team has a lot to work on, but the “Use Velocity as Flashvalue if available” option still has no functionality. A fix for this would be much appreciated, thanks!
Bumping this thread again was having the same issue on 4.10.1271. same setup as images. Nx-touch would interpret flash timed as velocity.
Please correct me if it is fixed on newer version
