NX Wing Manual
Is there an online manual for the Nx WIng?
The online documentation is at obsidiancobtrol.com. From there you can also access training videos. If you are running an NX Wing there should also be a manual in the Obsidian folder in the start menu. However, I can’t remember if that takes you to the online or if it’s a local copy.
