nx1 wlan usb adapter
Software Version: 4.30
NX Console Type or PC OS Version:nx1
hello, we try to connect a nx1 via second lan adapter to a wifi only for onyx remote. the usb networkadapter is recognized by the nx1 plugged in a usb a port on the back.
but how could we connect to our wifi, we can not find any options to fill in the wifi name and password? is this possible? thx
Is the USB-LAN Adapter wifi or wired? I would suggest a wired adapter and plug into a router? Then the tablet can join the router like normal. Otherwise, you might have to setup the adapter with a computer and then plug into the NX1.
it would be a great feature, to can access a wifi with only a usb to wifi adapter.
Hi @deflost
As ONYX consoles feature physical Ethernet adapters, there is no user interface available for searching for Wi-Fi networks and entering passwords. They will however appear in ONYX, as they will typically use the same drivers as a USB Ethernet adapter, which are supported by ONYX.
SSIDs and passwords are not stored on the adapter, so you won’t be able to preconfigure this Wi-Fi adapter on a different device first.
Hi
Other way to connect Tablet/Ipad/Onyx-PC is really to use an Acces Point device not a USB/VLAN
Inside AP you can to save SSID/password without software in NX-1 Where the Tablet/Ipad/Onyx-PC its could to go connected AP.
I hope that you stand me.
