NX4 Built In Monitor and External Monitor causing Dylos Issues
Do not use the calibrate touch screen (Do NOT Calibrate Touch Monitors in Onyx)
I would try using the identify touch targets and see if that resets it or you could try resetting the touch monitros and then the identify targets. It should ask you and allow you to assign the “location” of the monitor. Also make sure that in the dispaly menu you have an “additional” display enabled.
Watson
