Do you plan to add offset possibility in the patch to set offset for pan & tilt?
At leat 90deg would be really useful, but defining degrees would be the best!
I have issue almost in all concerts…
Thanks,
Kind Regards,
Adrienn
I don’t know about offset in patching, but I know you can set defaults.
I find it easiest to access by adding the Highlight window to the Function bar (Commands > Action > Highlight). Within the highlight window, choose the “Defaults” tab. It has tutorial text upon opening.
Hope that helps.
