Only one fixture has this problem where you can visually see that it has a lower intensity than the other auro spot movers. But all of the fixtures are in the same settings with intensity and the grand master is 100%.
Check if the shutter/dimmer is working correctly, maybe the mover needs a reset to defaults or dimmer calibration.
Also open DMX input/output window in onyx and check if all movers get the same value on the dimmer channel.
Sounds like a fixture problem, maybe part of the LED engine is not working.
