Some changes were made to make the Master Fader control work correctly.
Please reload affected showfiles and recheck.
https://files.obsidiancontrol.com/s/Onyx_4_10_1271
Release Notes for ONYX
(C) 2018-2024 - Obsidian Control Systems
This version requires Windows 10 or Windows 11 Home/Pro/Enterprise 64-bit for PC
All consoles require ONYX OS 4.10
Compatible with Obsidian NX4, NX2, NX1, NX K, NX P, NX Wing, NX Touch, NX-DMX, NX-Sync
Compatible with M-Series M6 (with ONYX Upgrade Kit), M2PC, M-Touch, M-Play, Martin 2-Port USB-DMX devices
Improved DyLOS factory content (26_Sep_2023): palette and alpha fixes, added (alpha) mask, transition and palette gradient folders.
Please note: Many parameter defaults and behaviors of fixtures have changed. Verify existing shows carefully as they may require programming adjustments.
4.10.1271 (06/08/2024)
Restored GM not controlling fixture master intensity channels for backward compatibility
4.10.1270 (01/08/2024)
Fixed submaster, inhibitive and playback faders not controlling master intensity channels
4.10.1269 (18/07/2024)
Fixed virtual dimmer on multi-part fixtures with non-master intensity parts
Visual fixes
4.10.1268 (05/07/2024)
Improved GTQ commands: both . (dot) and , (comma) are accepted to distinguish both cuelist from cue, and cue from “point-cue”
Fixed PARK FIXTURE setting 16 bit values to zero
Fixed direct (not via Manager) TCP TELNET connections (extended firewall rule)
Visual fixes and improvements
4.10.1267 (27/06/2024)
Fixed re-ordering 2D plan layers in some show files
4.10.1266 (25/06/2024)
Revised beat detection, added visual analysis feedback
Fixed surface controls becoming unresponsive until entering and leaving ConsoleTester or restart
Fixed clone operation (COPY FIXTURE) hanging when Fixture Groups are included
Fixes for DyLOS stability
Fixed GTQ to use programmed cue timing on UDP+TCP
Fixed recording new cuelists to playback buttons on XNET
Fixed RDM label/address change not moving on to value entry (assuming ‘@’) automatically
Fixes for fixtures with CMY emitters
4.10.1265 (17/05/2024)
Fixed FX Link state turning off unintentionally
Fixed added playback button not appearing on joined systems
Fixed disappearance of color indication on record merge of a preset when networked
Fixed GTQ X,Y command on UDP
Fixed DyLOS engine ignoring moved media content until restart
Fixed updating presets after EDIT PRESET session
4.10.1264 (26/04/2024)
Fixed parking fixtures to no longer ignore submaster/inhibitor levels
