Hi Everyone!
I am happy to announce the release of Onyx 4.10!!!
https://support.obsidiancontrol.com/…/Sup…/Downloads.htm
New Features
Added output overrides (Park, Default, Highlight, Offset) as special presets
- added parameter-level parking
- added channel-level offsets
- improved default value editing
- improved highlight/lowlight editing
Added output override feedback to live output
Added possibility to merge programmer contents into default values from RECORD popup
Allow P/T values in highlight/lowlight presets
Added “Copy from” between highlight/lowlight presets
Added Support for Telnet and UDP commands
Added input processors to DyLOS for converting external inputs into modulators
- added video and palette input processor (NDI)
- added audio input, filter and analyzer processors (NDI, ASIO)
- added Ableton Link support with Quantum Phase Synchronization and tempo changes in session (input processor)
- added MIDI Clock support (input processor)
- added beat-tap processor (replacing former global beat for chases)
- added reference processor (to decouple source input slot programming in presets and cues through indirection)
- added metronome visual feedback for beat rate
Enabled palettes in effect slots and masks
Added new “Preset C” mode to opacity mapping
Added aspect ratio control
Added color appearance support to input processors
Added options dropdown for library and beats editor views (library tabs can now be added as a view from the new “Library” Windows tab)
Added support for installing 3rd party ASIO drivers (to support low latency USB audio devices as published by Behringer, Focusrite, M-Audio, MOTU and RME), and added access to their mixer and configuration
Added audio monitoring
Added support for reverse playback for synced media playback and generators
Added visual feedback display modes for beat provider, which can be used in canvases or palettes
Added beat detection sync into media playhead and chase playback (beat triggers, next to global)
Added transport running state (Ableton Link, MIDI clock, audio signal presence) tracking to (un)mute beat provider output
Added beat-tap processors to F-keys (with target assignment)
Added reference processors to F-Keys (with target assignment)
