ONYX-1226 Fixed freeze when cloning cues containing time and weight values,
ONYX-1225 Fixed weight range 50% (“DEFAULT”) → 100% (“CUE”),
ONYX-1222 Fixed missing segments on some combined fixtures (like ACME Tornado) in 2D plan,
ONYX-1220 Fixed being able to disable NDI public group when no other groups available,
ONYX-1218 Fixed MSC command format popup not showing on small screens,
ONYX-1042 Fixed licensing issues for some PC systems, fader mini module (NX4, M6 with ONYX upgrade kit) in ConsoleTester,
Side note:
We were made aware of some older consoles experiencing lag on the touch screen after installing 4.32.1301. To correct this issue, please do a full OS reinstall using the 4.32.1302 OS.,
Some NX2/NX4 were unable to boot to larger USB drives to install the OS. To correct this issue, please update the BIOS using the file listed on the download page.
Today 8-1-2025 I updated my NX2 to 4.32 OS and it downloaded the 4.32.1301 and sure enough its all glitchy. I go on the forums and see this dated 28/7/2025.
Why am i able to download the bad file 4 days after this post? I have to do the whole process again.
Hello everyone, I’ve just installed version Onyx 4.32.1302 on my NX2 console, and everything seems to be working fine. However, I noticed that there’s a BIOS update available. I downloaded it and started the installation, but during the process—after the two windows shown in the BIOS installation tutorial—this screen appeared:
To avoid failing in BIOS update, please DO NOT remove the hard disk or USB or any devices.
When users update BIOS in any inappropriate way, that incorrect behavior will result in BIOS crash
and the NX2/NX4 controller cannot be powered on.
!!!!! After the BIOS upgrade, the NX2/NX4 will restart automatically and the screen may go blank for more than 1 minute !!!!
Press any key to continue . . .
AMI Firmware Update Utility v5.16.04.0135
Copyright (C) 1985-2024, American Megatrends International LLC.
All rights reserved. Subject to AMI licensing agreement.
Reading flash ------------------------------ Done
- ME Data Size Checking -------------------- Pass
- FFS Checksums ---------------------------- Pass
- Check RomLayout -------------------------- Changed
WARNING !!
The ROM file information does not match the system BIOS!
If forcedly update BIOS, it may destroy the System BIOS!
We strongly do not suggest to flash the BIOS!
Press "E" - This option will update entire BIOS region and exit.
Press "A" - This option will be no ROM update.
Press "F" - This option will be forcing to follow the command by user provided.
- Please select one of the options:
The NX2/NX4 BIOS update is only required, if you find that your NX2 is failing to perform operating system updates correctly. As your NX2 is already on ONYX 4.32.1302, this confirms your console performed the update correctly. Therefore, the BIOS update is not currently required on your console.
We only recommend updating the BIOS if absolutely necessary.
