Hi to all please have a look at when you rename the bank ,the comand line is not visible so if there is a mistake when typing,you need to rename it again,can you make the comand line visible please!
Just to be clearer I know how it it works, but I don’t agree on the fact that we need to click 2 times “1 to appear,1 to dissapear” then another 1 to confirm.
It should be 1and 1,but that only my opinion!
We are attempting to update the console to 4.8 from 4.4. We have been trying this for multiple days, and we have researched and studied every forum we could find to find a solution to what is happening.
Already we’ve done the following :
Tried multiple USB drives (from 8GB–128GB)
Updated the operating system as instructed by Matthias
Tried multiple USB Drives again (ALL USB 3.0)
Only used the blue ports in the back
*In an attempt to troubleshoot, use the side USB ports
We’ve turned it on and back off again? I don’t know, we are trying everything.
From what I understand, the issue that we are having occurs when we attempt to boot up the console from USB mode – yes, I have also tried to perform the update in CPU mode through Menu/System/Tools/update console election. – when in USB mode, the main screen goes black, and the small screen in the down right of the board is illuminated, but noting is happening. We have also tried leaving it in USB mode overnight to see if time was all it needed.
We updated the BIOs last week, I’ll give it another shot. Just so I know I am doing it right. When updating the BIOs do I go through CPU mode and the update console feature?
