Hello to all. After installing Windows, Onyx 4.4.11.86 first starts up normally. After rebooting, the system freezes when you open the show file. (
Windows 10x64) Please HelpWelcome…I would recommend making sure your windows 10x64 if completely updated (and all updates installed), and then restart and check again. Then if no new updates are found. I’d try installing the latest build which can be found here and see if that fixes the problem. It was just released and hasn’t made it’s was to the support site yet.
Thanks a lot. Version 4.4.11.90 so far works without problems. Shows open. I will test further))
