A new Onyx maintenance build has been published to the download page. Onyx 4.32.1314
Release Notes:
4.32.1314 (04/08/2026)
ONYX-1319 Fixed CLEAR, LOAD and SELECT PRESET on “Fan <>” masks
ONYX-1375 Blocked RECORD CUE to open-ended range
ONYX-1376 Fixed selecting fixture groups not resetting fixture selection first when values have been changed in programmer
4.32.1313 (20/07/2026)
ONYX-1280 Fixed issue where syntax could affect all parameters when editing Defaults/Park/Highlight
ONYX-1322 Support added for new hardware
ONYX-1328 Support added for NX DMX Gen2
ONYX-1338 Fixed issue where show files may not load, if the current show contains legacy fixture types that toggle between 8- and 16-bit parameters on the same channel (like Index/Rotate)
ONYX-1357 Improvements to show file load time when the fixture library has not been updated since last load
ONYX-1363 Fixed issue with FLASH+ACTIVATE on Playbacks 11 thru 20
ONYX-1365 “+” can now be used on an empty command line for additive fixture selection
ONYX-1371 Submaster and Inhibitive Cuelists can now be released using the Playback Control popup “square” release button
4.32.1312 (17/04/2026)
ONYX-1219 Added support for NX3 controller
ONYX-1320 Fixed inability of adding fixtures with too many conditional parameter layouts to a show
Maintenance builds undergo internal testing only, as they are primarily focused on bug fixes and minor improvements to the current release.
New feature releases go through a much more extensive development and testing process:
Individual Feature Development
Individual Feature Testing (Alpha)
Internal Combined Testing (Alpha)
Private Testing (Private Beta)
Public Testing (Public Beta)
Release Candidate (Stable Beta)
Release (Stable)
4.33 is currently nearing the end of the Individual Feature Testing (Alpha) phase, with features progressively moving toward combined internal testing. We expect the combined internal testing phase to be relatively short, as it is primarily focused on compatibility and structural testing before the build is distributed to external testers in the private beta.
We know this release has been a long time coming. Several of the new systems are substantial changes to ONYX, and we’re taking the time to build and test them properly rather than rushing them into users’ hands before they’re ready. The goal is not only to deliver these features, but to make sure they’re reliable and provide a solid foundation we can continue building on in future releases.
Can you already spoiler what new features will be in 4.33? Mostly interested in the new FX engine and more flexibility in assigning buttons/faders to individual cuelists. Is that part of that new release?
