I have the NX2 console.
Trying to assign a Mac 101 intensity to a submaster
When I do it strobes!!
Looking for help.
Thanks!
Tommy,
It sounds like you accidentally recorded the shutter channel control into the submaster also. Try removing that attribute.
The fixture should not strobe when you put the Intensity to 100%. I suspect you may have it in the wrong DMX mode.
Tommy,
After seeing your video, I would agree with Matthias. Please check the fixture mode (on the fixture) and the DMX start address. Make sure they are the same as what you have patched.
