I have a bug in the situation where I disable the P/T combo for a group of fixtures with different type: With P/T combo I can design an animated (Fx) TILT movement. On disabling the P/T combo this TILT animation turns into a PAN animation. Enabling P/T combo again, it turns back in a TILT movement.
It seems that the channel ID for TILT and PAN is getting disorded by disabling the P/T combo.
I experience more than this problem with P/T combo switch.- Also if you have two cue lists with switched off P/T combo, the one with only TILT animation can block the PAN of the other cue list. Even if you disable the P/T combo and you do not have any value set for the PAN on the first cue list.
Maybe I should mention that I am working with Presets.
And there are other cue lists on lower priorities which are also dealing with the same fixtures. partly with P/T combo ond and partly with P/T combo off. Unsing different presets.
So, there seems to be a group of problems around the P/T combo.
Update: If you do not use a preset, it seems to be running better.
