Running the latest release versions for PC and the NX1.
Looks like the NX1 is behind on it’s versions.
When will the NX1 OS be updated to match the PC version?
What version is the PC on and what version is the NX1 on? If the NX1 is on 1243 and the PC is on 1244, you can use the PC setup file to update the NX1 to 1244.
Thanks!
I thought I had to only load the OS version.
I didn’t know I could load the latest version like that.
Got everything work, thanks for your help ![]()
