ONYX Release 4.30 - End of Support for Legacy Martin Hardware
We want to inform you about an important update regarding our legacy USB products (M-Series licenses and hardware). With the release of Windows 11 (24H2), Microsoft has introduced significant changes to its encrypted security structure, which directly impacts ONYX. To ensure continued compatibility and security, ONYX has updated its internal licensing and driver support to align with these new requirements.
Unfortunately, this means that legacy Martin USB products and license keys can no longer be supported.
We understand this news may be unexpected, and we want to assure you that this decision was not taken lightly. The changes in Windows security were beyond our control, and we are committed to supporting you through this transition as best as we can.
Thank you for your understanding and continued support. Please don’t hesitate to reach out to our team if you have questions or need assistance during this process.
Sincerely,
Obsidian Control Systems
Release 4.30.1274 of ONYX is a new software release recommended for ONYX Consoles, USB devices and PC Systems listed below. These release notes detail the new features, enhancements and bug fixes that have been implemented. https://support.obsidiancontrol.com/Content/Support/Downloads.htm
ONYX Consoles:
Requires ONYX OS 4.10
  • NX4
  • NX2
  • NX1
  • M6 (ONYX Kit)
ONYX USB Interfaces:
  • NX P
  • NX K
  • NX Wing
  • NX Touch
  • NX DMX
  • NX SYNC
  • ONYX USB License Keys
NETRON EtherDMX Nodes:
All NETRON nodes unlock 4 Universes (requires Art-Net protocol for license detection)
Free ONYX Universe:
Universe 1 is free to use for any applications using sACN or Art-Net protocols.
Windows Compatibility
ONYX for PC Systems supports Windows 10 and 11 (Home/Professional/Enterprise 64bit). ONYX is not compatible with ARM processors
DYLOS Content
Please install the the improved DyLOS factory content (26_Sep_2023): palette and alpha fixes, added (alpha) mask, transition and palette gradient folders
Fixture Library
This release includes the ONYX Fixture Library December 02, 2024. For latest library files and to request new fixture profiles visit
https://support.obsidiancontrol.com/…/Fixture_Library.htm
End of support for legacy Martin hardware
Updates in Windows 11 (24H2) introduced significant changes to the encrypted security structure utilized by ONYX. The changes required software and security adjustments which are integrated into ONYX 4.30.
These adaptions unfortunately cannot be applied to legacy M-Series licenses and hardware as they are locked into their encryption scheme. This scheme was rendered obsolete by changes in the Microsoft Operating System and the licenses are blocked by the latest Windows 11 version.
ONYX 4.10.1271 is the last version supporting M-Series licenses, license keys and USB devices.
The following Martin devices are no longer unlocking ONYX and are not supported as USB control devices:
  • LightJockey Key
  • Martin One Key (all versions)
  • M2PC
  • M2GO (USB Mode)
  • M2GOHD (USB Mode)
  • M-Touch
  • M-Play
  • M-DMX (M-PC 2U)
  • USB Duo DMX
  • Universal USB DMX
  • Martin USB DMX
  • Enttec USB DMX
  • M-Sync
  • M-Series Modules
  • Maxxyz Compact
  • Maxxyz
It is recommended to utilize Windows 10 or Windows 11 pre 24H2. Obsidian can unfortunately not guarantee that future updates on Windows 10 will not cause blocking of the encryption keys due to ongoing changes in Microsoft’s security requirements.
To create a reliable PC system for long term support of legacy hardware consider a dedicated PC System using the Windows 10 LTSC 2021 license which can be obtained from online retailers for a low fee.
All downloads for legacy consoles and PC installers can be found at https://support.obsidiancontrol.com/mseries
For the foreseeable future Onyx Library packages will be compatible with Onyx 4.10.1271 and Obsidian will provide library updates and support fixture requests for all Onyx 4.10 users. Compatibility Notes
  • Parameter defaults and behaviours of fixtures can change. Verify existing shows carefully as they may require programming adjustments.
  • Some DYLOS default parameters may have changed. Review all cueing and playback and adjust as needed.
Update Instructions
Please ensure that show files are saved to an external USB drive before proceeding with the update, and carefully follow these installation instructions:
  • Installing/Updating Onyx on a PC
  • Installing/Updating Onyx on a Console
For assistance, please contact Obsidian Control Systems: support@obsidiancontrol.com
Firmware Updates
DMX firmware was updated to no longer stop DMX output when in the settings menu. The following DMX devices can be updated from the Diagnostic Tools Menu https://support.obsidiancontrol.com/…/System_Settings.htm
NX1
NX P
(E1A9) NX-DMX2 Controllers (V4.14)
NX2 NX Wing
(E0A9) NX2 NXWing DMX (V4.14)
NX DMX
(E0AA) NX-DMX (V4.14) (E1AA) NX-DMX2 (V4.14) 4.30.1274 (02/12/2024)
ONYX-1097 Fixed ONYX license unlock on Windows 11 24H2
ONYX-1097 Removed M-Series licenses and device support due to Windows security changes (except M6 with ONYX upgrade kit and connected modules)
ONYX-1106 Fixed highlight issues after adding types
ONYX-1075 Visual fixes and improvements
ONYX-1070 Fixed mark bug (causing fixtures to flicker)
ONYX-1071 Fixed (empty) cue follow bug
ONYX-1069 Fixed wrongful conflict popup when copying multiple cues into point cues
Firmware fixes for NX DMX and NX1/NX2/NX-P DMX boards to not stop DMX output when entering DMX settings menu (Identify mode)
ONYX-1074 Increased fixture part limit for pixel mapping (to 65534)
ONYX-970 Fixed command line fanning
ONYX-1076 Fixed color temperature increments (repeating first semantic)
