ONYX Release Candidate 4.5.1214
EDIT: replaced with 1214 after a defect in X-Net was reported
The ONYX 4.6 development cycle is now completed. Some minor housekeeping remains, but this version contains all planned features.
This version changes the licensing system. Be careful when testing this as the “free” Universes are changed. So if you do not own a ONYX Wing or Key be mindful of the Universes you need.
EtherDMX Universes are now REDUCED to 1 free Universes unless Obsidian Hardware is detected.
Netron devices will require a firmware upgrade to enable ONYX unlocking, it will be available with the 4.6 release.
For a summary of the licensing changes please see:
New ONYX 4.6 Licensing for PC Systems (obsidiancontrol.com)
Download the Release Candidate 1213 for consoles and PC:
https://files.obsidiancontrol.com/s/ermanRJL64PLzkW
Ensure to keep the latest library installed, which is replaced daily. The RC1213 contains the 06/2021 library.
Download the package and report all issues back using the 4.6 form.
Fixture Library (4.6 Preview) (obsidiancontrol.com)
Current content package:
https://files.obsidiancontrol.com/s/C8mSn6owEYLAgRJ
The complete list of changes since 4.4:
		Release Notes for Onyx
	(C) 2018-2021 - Obsidian Control Systems
4.5.1213 (21/06/2021)
Added white mapping mode to DyLOS to include all emitter channels (e.g. white, amber, lime) in pixel-mapping to better represent unsaturated colors on stage: it also uses color information and relative brightness data of all color emitters to balance emitter brightness, as well as apply color temperature across emitter channels for unsaturated colors
Added “intensity + other emitters” mapping mode for fixtures without RGB emitters but with various other emitter types
Added “background color” effect and “masks as background” mode to masks
Added “DMX OUT” option in LOAD popup window to “freeze” effects output into the programmer
Effect/timing channels can now also be used as “[SELECTION] @ Parameter Button” for direct entry and fanning on the command line (digital values only: swing ranges 0-170, other attributes 0-1000)
Applied new license scheme (Nova/Essential/Premier/Elite)
Applied programmer and cue values panel improvements to live output
2D plan now visualizes all color emitters
Added edit cue button and the direct cue view to playback context popups as well
Keypad show/hide toggle can now also be assigned to an F-Key
Time for automatically loading the current show on startup can now be configured
Fixed Art-Net IN loopback issues
Fixed UI disappearing after selecting cuelist type when recording to a new cuelist
Fixed custom colors on fixtures, types, cuelists, etc
4.5.1212 (16/04/2021)
Added color palette generator/editor
Added fixture type filter to programmer and cue values panels; fixes and improvements
Added Art-Net/sACN source IP input filtering
Added DyLOS thumbnail feedback options
Library conversion improvements allow for more fixture types to be added to a show file again
Fixed UPDATE+UPDATE to referenced preset(s) not updating cue values
Fixed cleaning faulty fixture types from show files, preventing adding fixtures when type was fixed
Fixed DyLOS generator animation
Fixed DyLOS opacity mapping
DyLOS Framing and Iris will now follow opacity mapping (indicated using hatching pattern)
Various fixed and improvements
4.5.1211 (19/03/2021)
Fixed DyLOS channel assignments
4.5.1210 (18/03/2021)
Fixed DyLOS enabling and update issues
DyLOS thumb overlay fixes and improvements
4.5.1209 (16/03/2021)
Added configurable DyLOS thumb overlays, optionally showing curves for matrix generators and mapping gamma curves
Fixed fixture type library browser issues (like popping up again after adding fixtures)
4.5.1208 (11/03/2021)
Improved programmer and cue values panels:
- Improved integration with scroll and toolbar workflows
- Added fixture names & colors, and fixture type colors
- Fixed issues with fixture(-type)s that have large channel footprints
- Improved performance
Added Fixture Type validation rules to avoid show file corruption: option is provided to save violation report, which can be submitted with library update request
When a DyLOS update introduced new channels, a popup is shown to apply optimal assignment to parameter groups, which applies best guess merge with legacy and customized assignments
4.5.1207 (17/02/2021)
Added DyLOS zone output panel
Improved parameter rendering
Anti-aliasing in DyLOS can be disabled for better pixel accuracy
DyLOS framing now is corner point oriented instead of “blade” oriented
4.5.1206 (03/02/2021)
Added current universe fixture filter in patch
Improved Art-Net and sACN input options
Improved orientation of fixtures on Capture import
Fixed first fixture in patch not having its opacity mapped correctly
Fixed fixture selection focus for multi-part fixtures without a main part
Fixed LOAD+LOAD using keyboard shortcut
Fixed copying between types of Fixture Groups
Fixed playback fader (1-10) LEDs on M-Touch, NX Touch while not in “Play” mode
Fixes for fixture type search
Additional fixes for applying additive color FX macros
4.5.1205 (18/01/2021)
Added DyLOS mirror effect
Added DyLOS tunnel effect
Added framing and iris to DyLOS zone slot
Added DyLOS frame blending
Continous/loop improvements on DyLOS
Installer improvements to avoid SQL-related errors in uninstall of 4.5.1205 builds and later
Fixed fixture rotation on 2D plan being ignored for pixel mapping
Fixed pixel mapping to ignore master parameters specifically
Fixed importing AtlaBase parameter group assignment into new show
Fixed applying additive color FX macros
Fixed error popup in selected cuelist view when using keyboard shortcut to delete cues
Fixed saving types in library editor
4.5.1204 (24/12/2020)
This version introduces a new fixture libary format, provided by the new libary partner AtlaBase. This library includes almost 50.000 fixture profiles
Please review all required fixtures carefully and request missing fixtures and report errors, wrong defaults etc on the new fixture request page for Version 4.6
Existing fixtures will remain in the showfile but can be replaced using the “Exchange” function in the patch menu.
User fixtures and the Library Editor are not affected and remain available.
This library is only availble for Version 4.5 and higher. Previous 4.2 console versions will receive an update to enable support for the new library.
Until release both library systems remain actively supported.
New fixture library format
Daily update of new library package on Obsidiancontrol.com
Single file library package (no longer an installation)
Faster software install, bootup, library udpates
Update libary from System Menu /Tools/Maintenance
Library data is perfectly syncronized with Capture fixtures, allowing for easy import of the patch over CITP
Revised Parameter Defaults and Snap Rules(e.g.additive LED fixtures now have all colors defaulted to 100%)
-> this can affect existing programming and cues and presets must be adjusted if needed.
Enhanced real world values (e.g. Zoom Ranges, Shutter Speeds, Framing Blade Angles)
Improved Parameter names and feature descriptions
Enhanced gobo and effects bitmaps, color buttons for CTC and Color Wheel Selections
Completed 3-preset pixel mapping mode and opacity mapping modes - BREAKING changes for existing shows using this feature
4.5.1203 (19/11/2020)
DyLOS values are now shown in live output (origin indication pending)
Improved 2D plan performance and responsiveness for large fixture sets
Fixed optimizing show files (removing fixtures that had been marked for deletion)
Fixed placing multi-part fixtures on 2D plan
Minor fixes and improvements
4.5.1202 (29/10/2020)
Fixed highlight
Fixed DyLOS folder selection
4.5.1201 (21/10/2020)
Added 3-preset pixel mapping mode and opacity mapping modes
Fixed application window lags while moving on some systems
Fixed 2D plan orientation pulled in from Capture 3D positions
4.5.1200 (21/09/2020)
Added DyLOS generators:
- Patterns: Plasma, Voronoi
- Nature: Fire, Steam
Updated NX Remote app
Fixed M-Play bank issues
4.5.1199 (30/07/2020)
4.5.1198 (24/07/2020)
4.5.1197 (10/07/2020)
Improved P/T Combo handling
Fixed joining shows
4.5.1195 (08/06/2020)
Added MSD (CITP) integration
4.5.1194 (02/06/2020)
Hey there!
Having some issues with Network Devices, specifically joining or pushing a show in 1213. Both computers are identifying each other just fine and are able to start the “load show” process. The issue is during the loading process. the primary changes over to the “Primary” and the other will load, hang for a bit, and then successfully load the show, but in standalone mode. The primary computer will then go back into standalone mode as well.
I’ve tried to do this over the network, directly connected, over different network adaptors, and still have the same result.
Thanks!
Please can you explain the correct procedure to use the new "load and capture dmx out from an fx? "Each time I try fixtures slightly move themselves respect their current position!
thanx = )
Same issue here for me
Using the new Load feature to capture “dmx raw values from FX” has issues! after the load comand what happens is that the Capture , slightly moves all fixtures from the current stoped position!
Hey! Having some issues with screen tearing on some UI elements that I’ve never experienced before this Beta. So far, panning through the 2D plan and moving the FAN line has some stuttering.
hello, we can confirme that the ui is tearing when moving fan line in fan window.
thx.
r.h.
Replaced with 4.5.1214 due a missing X-Net file.
Confirmed, its a visual issue, shouldn’t have any other effect.
The patch manager just accepts one digit numbers from my computer keyboard. For 2+ digit numbers i have to use the internal keypad
Or the numeric keypad on your keyboard: the row of digits in the top row of your keyboard is considered text, allowing you to enter names that start with digits, without interfering with the numerical selections you enter
As explained by Gert, this is not Beta related, and always been like that… Number entry is done by the Programmer keypad, or left number keypad, on a full PC keyboard
Regards,
Ofer Brum
Onyx Library Support
Thank you, I learned something new
LOAD OUTPUT WITH FX
This is still not working for me in this case:
Here as an example I have simply created an fx ,“so it’s running” did not store it to a fader, just the speed fader ,and i was stopping it at some point.
What Onyx does is, it saves my first pan tilt when I stop the fx, then if I leave the fx run again and stop it again at some point, seems it doesn’t work.
Looks like after the first record maybe I need to clear ?
So maybe I can’t use it in this way?
Or am I wrong?
Maybe I can’t stop a running FX that is not stored in a fader? and then record it as pan tilt.
Can you Pplease explain to me the correct procedure!
It’s a bug and has been fixed for the next build
THANX !
With the “NX WING " can I use this window, any shorcut or is it assignable to “F KEY” , or is there a hidden command somewhere ?
This feature is really useful for theater use!
Please don’t tell me CUE " 5” enter.
…so where is it?
Chauvet COLORband T3 BT
This 2D fixture scale used to be a good size, now it is too big to be used even when scaled down.
thanks :relaxed:
Hay dog… did ya see the size of that chicken?
Please report this in the library request form:
