Onyx V4.10.1271 - CPU throttling when using Dylos (Intel Core i5-4250U
Hi all,
not sure if this is something that only happens to me and my machine, but when I start activation any function in Dylos the CPU is more or less stuck to its base speed (1,3GHz). Stopping the Dylos activity again directly allows the CPU again to use more GHz.
Not sure if this is a bug only in this Version or was the same on others versions as well. I started using Dylos a bit more in the mentioned version and started recognizing this behaviour.
Thanks for your support.
Philipp
Do you have any thermal throttle issue which can make the processor reduce its own frequency for safety?
nope the CPU Temp is about 55°C. So in a total normal range. I fully reinstalled Windows to have that sorted out, but the behaviour is still the same. Its not fully stuck at 1,3Ghz but the CPU is noticible slowed down then. Not sure if that could be related to the internal graphics part of the CPU being used when doing stuff with DYLOS.
Is there something else I could check to get behind that?
Thanks
Philipp
