Override for move fx
Hi there
Im wanting to create an override for pan/tilt fx but without the fader altering the speeds. I would like the speed to be the same as when I recorded the cue. How can I create the override to just alter the PT swing amount? Currently, my fader alters both PT swing amount and speed.
Cheers
Record a Override in a way like this:
  1. Select the devices You want the pan tilt swing to alter.
  2. Seelect the PAN/TILT attributes.
  3. Got to FX section.
  4. Move only the pan and tilt swing to desired values. (don’t touch any other things)
  5. Record this on the fader.
    this should make the override for PAN/TILT swing only.
Brilliant, thanks Mike.
