Hi All ,
Two questions :
- Is there a way to see the Palette name in a DMX output view ?
- Is there a way to make the main Back/Pause button just be Back with no Pause ? ( like in the Cuelist options for separate Cuelists )
Thanks ,
Tom
Hi All ,
Two questions :
Okay , solved my question 1 . I was using the wrong view to see Palettes in cue , I need to use CueList Values screen to see Palettes , not DMX Output screen .
Hey @TDTLS ,
On question number 2……do you want the back to maintain timings? If not, you can press and hold “Snap” as you press “Back”. This will be instant. So no timings. Not sure if that is what you want.
Hi Watson ,
Yeah , that is the workaround I have been doing . I was just wondering if there is a way to assign the Main Back / Pause button to just Back , the same as you can do in a fader Cuelist option .
Thanks for the help ,
Tom
