could be put in the next version:
A Pan inversion in degrees or at least 45 degrees?
it is very difficult for me to work with 200 machines and I need to adjust 40 muve presets, so it was a faster way to get the machine in the right position!
Hello Ze_Rodrigues,
Do You know, that You can click PAN or Tilt invert t in the patch list for any device, and also You can do the invert via RDM if Your fixture supports it.
