Pan Tilt in Dylos
I am having issues getting pan/tilt effect to work in DYLOS, I am going to the mapping tab and going to preset 1 and hitting pan tilt. I have no presets in there. I know I am missing a step but not sure what.
@jsnmllr1981 - welcome to the forums. As this is your first post, I’m not sure what comfort level you have with ONYX. I’m going to error on the side of beginner.
That said, to use DyLOS with Pan/Tilt there are many options. But for simplicity, before you even go to DyLOS just record two basic Pan/Tilt locations as Presets (ex. Upstage and Downstage). Once that is done, when you go to DyLOS and choose Mapping, select the 2 Preset option, and then the Pan/Tilt Preset category. You will assign one preset to Mapping A and the other preset to Mapping B.
I’m also just clarifying that you have to have these fixture(s) placed on a 2d Plan View with a DyLOS zone around them. If you have not already placed a DyLOS zone (if this is the first) you will need to enable them and make sure the DyLOS content is loaded.
Thanks, I just never had any possition presets. Everything else is set up just fine.
