patching problem
Software Version:4.32
NX Console Type or PC OS Version: adapter
unable to patch Apextone Beam 295W, didnt found the same light and i tried to manually make it in library editor, also didnt work
@ibra176 - Welcome to the Obsidian Forum.
I’m sorry to hear that you are having issues with your fixture and ONYX. I would suggest that you submit a fixture profile request to the library team so they can build the proper profile. They will need information from you (fixture website link, manual, desired modes) to build the desired profile needed.
You can also try searching the ONYX library for “Beam 295w”. There are several “unknown” manufacturers that might have the same DMX profile / layout and would allow you to control your unit while a proper profile is being made.
I’ve attached the web link for where the request can be made.
ONYX 4.6+ Fixture Requests
