Permanent CUE without edit or update.
DMX Control and CRMX is more and more common on small film and feature sets. I would suggest a CUE with auto updated setting or something like “create Fader INT CTC GM for Fixture XY to XY“ and what i miss the most is “remember fader position“ without manual setting those.
I use OnyxOn PC on a SurfaceBook3 and Netron Nodes.
Hi @RKlein
Welcome to the forum.
This is an interesting idea. So to confirm, you would like a quick way of creating three override playbacks per fixture: one for Intensity, one for CTC, and one for Tint, and for these to then be repeated for a defined range of fixtures?
For this, you would probably be best to set a fader to the position you need it in, and then store the current level as a new cue, potentially even on the same playback fader. You can then raise the playback to full and play back this cue, to jump to the defined level without needing to worry about setting the fader to a specific level.
Hello Edward!
Thx for your fast response
“This is an interesting idea. So to confirm, you would like a quick way of creating three override playbacks per fixture: one for Intensity, one for CTC, and one for Tint, and for these to then be repeated for a defined range of fixtures?”
Yes. But they have to remember their Values somehow.
Like a Preset or CUE which Stores “Fader Position “
1.1@23% ( Fixture #1 0% to 100%)
1.2@45 ( Fixture #1 0% 3200K to 80% 6500K)
1.3@50% (Fixture #1 0% -green to 100% +green)
I know this is not how a CUE based System works. But on fast paced Sets. Select Fixture - Select Intensity - raise or lower value - Update CUE
Is a bit too Slow.
Best would be Select CUE which acts as a GroupMaster and alle Fixtures/Groups Jump to their Values - Submaster and/or Overrider.
Maybe i just missed a way to do this.
Thank you very much for the suggestion. I have logged this idea as ONYXRM-97 on our system.
