I have a playback II module that used to work with onyx but I cant get to work now. It shows up in the firmware update but doesnt sync to what’s happening in the software. Should there be anything under IIC Devices?
There should be something in IIC devices indeed, but only when the Playback Module itself is selected… Did you try that?
Well I reset all of the connectors and it appears to work now. I now show (2) Playback Module II Devices, only one contains any IIC devices though. So that seems strange.
Yes indeed, if reseating the connectors doesn’t help to show the IIC devices when selected, it will probably need servicing (might simply take reprogramming the IIC firmware using a direct cable, your distributor may have the kit to do that).
