Presets - Dimmer vs Intensity
I have some 3ch lights that are using the Virtual Dimmer, which is assigned the parameter name, “Intensity.”
I also have some 16ch lights that have a Dimmer channel, which is shown with the parameter name, “Dimmer.”
Earlier today, I was able to select all my lights and create a preset for intensity 0 and another for intensity 100. Both of those presets work correctly for all lights. However, when I tried to create some 25, 50 and 75% presets, I can get it to work for lights with the Intensity parameter OR the Dimmer parameter, but not both in the same preset.
What did I do right the first time that I’m doing wrong now…?
I found the solution. When recording the preset, have to use the “Merge” conflicts option.
