I know how to delay a cue across selected fixtures, but is there a way to release with the same delay? Preferably a follow delayed release
There is no function for a release delay.
Gerry,
Not sure if this could be a possible “work around”, but at the end of your cuelist, could you record a “dummy cue”? Then assign a Marco to the dummy cue to “release this cue list”. In the setting of the cuelist (cuelist options) you can set the release time. You can also change the cue trigger from a “Go” to a “Follow” and then it will follow at the desired time and release at a different time. Maybe between these settings you can accomplish what you want.
