I am using QLC+ to send SACN to a Grandstream managed switch with a Netron EN4 and a City Theatrical Multiverse transmitter as clients.
The Multiverse transmitter accepts the SACN and all of the fixtures respond to the controller without issue.
The Netron node handles the SACN feed erratically. I’m consuming SACN on two output ports. Here are some of the issues:
- If only the first hundred or so DMX addresses are sent from the controller, the Netron sometimes indicates that it is receiving the SACN data as indicated by a solid blue light. However, this is intermittent and the light will often change to blinking blue.
- Another group of fixtures starts at address 201. When these fixtures are in universe 1 of the controller the Netron always blinks blue.
- When the same universe of SACN data is mapped to both output ports, I often get blinking red lights.
In all cases, the City Theatrical Transmitter continues to flawlessly consume the SACN feed.
Everything works if I switch to Artnet, but my ETC multiverse fixtures consume only SACN, meaning that I have to loopback universe 1 (SACN) and duplicate it on Universe 2 (Artnet), complicating the infrastructure.
This seems like a bug in the Netron firmware, as the SACN data is not an issue for the multiverse transmitter, and working Artnet seems to role out any connectivity issues. Possibly the SACN protocol requires something that I’m missing in the router or switch configurationbut the lighting network is an isolated VLAN.
It’s also eerily familiar to:
I’d prefer to get everything working using SACN only to reduce the complexity and make trainign others easier. One last remark is that the Netron controller sometimes becomes corrupted after working through different configurations, requiring a device reset. That issue is far less frequent and I believe unrelated.
Any thoughts on how to get the controller to work properly with SACN?
