[SELECTION] @ Parameter x THRU y THRU z ENTER not working
In the Onyx manualy, I see under Commandline → Commandline Reference → Command Line examples: “Parameter Commands”. The last row in the table says “[SELECTION] @ Parameter Button 0 THRU 100 THRU 0 ENTER”: “Spread the Value across the [SELECTION] from 0% to 100% to 0% (e.g. @ Iris 0 > 100 > 0 Enter)”
I select some fixtures, then “@”, then click “Red” parameter, then “100 THRU 83 THRU 100 ENTER”.
But nothing happens in the programmer… I’ve tried multiple variants of this but nothing works. Is this a known issue?
I can confirm that I tried many different “commands” and could only get Intensity to behave as intended.
Thank you for reporting this issue.
I have logged this as ONYX-1103 on our system, to allow our software team to investigate further.
Two-point and three-point parameter fanning can be achieved through the graphical fanning tool in the Channel Visualiser as expected.
Thanks @Edward. That is what I’ve done as a workaround, but isn’t quite as precise as the command line and a bit clunkier. Would be great if the command line were fixed
Thanks!
No problem at all - we’ll get this fixed in a future update.
@Edward any update on this? Is this fixed in the latest release? Thanks
Yes - this is fixed in ONYX 4.30.1274…
https://support.obsidiancontrol.com/Content/Support/Downloads.htm
