Hi to all, so if using the keypad to select a preset the “set selection parameter” even if I touch" pan tilt" that is selected and visible in “cmd line”. Only the intensity is always “highlited” can you fix that?so if I touch pan tilt highlite will go to pan tilt!
thanx!
Clicking the PT as part of the command shouldn’t change the selected context on the parameters. I’d say this is intentional.
