Hey guys I was wondering if there was a way to change the timing of when the color changes in the fixture?
When I run the cue for my lekos they start up and then snap to the color rapidly. Wondering how to make this a bit smoother.
I’ve tried to fade the cue but it’s not giving me what I want. Any Ideas?
For a start I would do this:
When in cue list directory double touch the desired cue list or on pc right click.
Click the gear wheel.
Check in General tab if You don’t have any Release and fade in settings wrong.
LED color fades should be smooth. Hard to tell from the limited information here but the first thing I think of that kind of sounds like it might be what you might be seeing…
If you haven’t already, try setting all the LED color attributes to 0% in the Default Preset for those fixtures. I’m not sure from your description, but that might resolve what you’re seeing.
If you’re manipulating each of the separate LED color attributes yourself it should be smooth.
But your comment “switches from open to kelvin (ex. 3200K)” seems to indicate that you are using a color macro attribute in the fixture - that has different color temperature settings. Is that the case? If so, that might be dependent on how the fixture implements that color macro.
Providing the exact fixture brand and model, and which Onyx fixture profile you are using would also help.
