Show Cockpit OSC Midi controller lag
Hey everyone.
So I have been having this issue for a while now and I am not sure what could be the cause.
My setup consist of the latest version of Onyx on PC with a M2 GO with Show Cockpit
For midi controllers I have used APC mini mk2 and 3 and have now switched to a novation LAUNCGPAD MINI mk2
I map my buttons to my playback buttons in onyx.
When I starteverything up, its super responsive and snappy.
which is great because I use this to have all my flash cues, for things like strobes.
Usually after 30-45 mins, sometimes earlier or later. The midi will stop going thru the OSC for about 30 secs or so. During that time frame, any midi inputs that I did essentially buffer. Once the OSC starts working again, all those Midi inputs go thru.
This has replicated itself across multiple versions of onyx, show cockpit and midi controllers.
I’m not sure what could be the cause of this, and it is something I would like to figure out how to fix.
Any ideas or insight would be greatly appceiated
