I all have RGB lights, and I want to put then into an m-play fader. Something very easy, one fader = 1 color or led. When I save into a fader, I think I have to select cues beceause submaster would not register the color data. When I fade the cue, it does work however all parameter changes. I would like, as soon as I put the fader is at 1%, that all color parameters snaps, so that the fade would be made with the right color, instead of having intensity AND color fading at the same time.
Just for reference, the light would be set blue at 100%, however when I start the fade, it is white and when I fade, it becomes blue. If I want to stop at 50%, I will have blue and white turned on.
I am not sure about changing the default fixture color, as it will make a double pertage (Ex: 50% intensity and 50% blue = 25% light output)…
Thanks!
