Hi
Long time ago M-Series supported CRMX hardware from Lumen Radio
https://lumenradio.com/martin-professional-chamsys-add-support-crmx-nova-usb-dongle/
Is It still working?
Hi
Hi Eduard,
That dongle relies on the Enttec support, which is no longer available in ONYX.
I don’t understand you, Do you refer that the USB support Lumenradio is the same that Enttec interface?
Correct, it uses the same drivers sytems as enttec and would appear on your console as an enttec device I believe.
All this is no longer possible, please choose a different CRMX device.
ok… issue closed. Thank you
