Take off an ID
Hi
A question
How I can “delete” an ID completly into CL??
Ex; I have a couple CUEs into CL…and a couple ID fixtures and I need delete and ID but not on patch
Thank you
Eduard,
Are you referring to removing a FIX ID from a specific cue?? EDIT, CUE (x) ENTER. CLEAR, FIX ID, ENTER. UPDATE.
Or are you referring to a FIX ID(s) from a range of cues (or entire cuelist)? RECORD REMOVE
See these sections of the manual.
http://support.obsidiancontrol.com/Content/Cues_and_Cuelists/Record_Options.htm?Highlight=record%20remove
http://support.obsidiancontrol.com/Content/Cues_and_Cuelists/Removing_Attributes_from_Cues.htm
