The manual says this about the Cue Only Option: “When selected, information that is recorded into that cue will not track forward. It will be contained only within that cue. The one exception to this is when “Cue Only” is selected and you record a new cue at the end of a cuelist. In that case, the information will track forward.”
So after trying it out it doesn’t seem to work. I recorded a Cue with FX parameters and the Cue Only option and then recorded another cue. In theory nothing form the first cue should track to the second cue but it did. Im not quite sure what I’m doing wrong and some help would be very appreciated
