Software Version: 4.30.1274.0
NX Console Type or PC OS Version: NX Wing
I have six cuelists based on timecode, each running within a specific time range:
Cuelist 1: 00:00:05 → 00:05:00
Cuelist 2: 00:05:30 → 00:10:00
Cuelist 3: 00:10:30 → 00:15:00
…and so on.
I receive timecode via MIDI and want to create a main cuelist that triggers each of these cuelists at their respective timecodes. For example:
At 00:00:05, the main cuelist should trigger Cuelist 1 while keeping control.
At 00:05:25, it should trigger Cuelist 2, and so on.
The issue is that when the timecode reaches 00:00:05, it activates Cuelist 1 but also stops the main cuelist, preventing it from continuing to trigger the other cuelists.
How can I make the main cuelist remain active and continue executing time-based triggers without stopping itself?
Here’s a screenshot of my current setup. Any ideas on how to fix this?
Welcome to the forum. Thank you for the screenshot.
In your show file, Cuelist 91 will trigger Cuelist 58 and release all other cuelists when it receives timecode 00:00:00:15. However, cuelist 58 is configured to release all cue lists apart from itself when triggered. Therefore, cuelist 91 will be released.
Apologies if I have misunderstood something, but it looks like you may need to edit cuelist 58 so it doesn’t release cuelist 91 when triggered.
